NSPanel Pro V4.0.7 Optimized Version Released
@derPate1989 we plan to provide a system screensaver to manage the Display (screen timeout) as discussed in this topic. Isn’t a screensaver good enough for your usage scenario? You need the ability to turn on/off the screen programmatically?
@alyusuph
Do not forget ZHA users as by focusing too much on MQTT.
Um, I don’t understand it. ZHA does not conflict with MQTT, right? You can use ZHA to manage your Zigbee network and devices, but it doesn’t prevent you from integrating other devices through MQTT, such as tasmota devices.
Hi! Since version 4.0.x is currently in a limited rollout phase and only deployed to a subset of devices, we’d like to invite you to join the testing program. If you’re interested in trying the new version, please share your device id with me. I’ll be happy to add your device to the 4.0.x group.
The v4.0.x firmware is now in phased release process, so some users will get it sooner.
If you are interested in testing it and don’t mind encountering bugs, please send me the deviceid of your NSPanel Pro 86/120 through private message.
As you can see, we have released 7 bugfix versions till now. We’ll probably release another 2 or 3 bugfix versions until we open the OTA for everyone.
Yes i think a screensave would be nice, Maybe an additional Option for Turn off Display would be also nice. :slight_smile:
You are still improving it is excellent. Yesterday I installed your nspanels.
Fast and looks nice. only the setup was a hassle, since the internet is not stable at the moment.
I am going to install more ns panels to customer.
Hi, ewelink-smart-home v2.6.1 has been fixed, you may now upgrade to the latest version.
I confirm.
Works. :+1:
Thank you.
Regarding TRZV, keeps connecting and disconnecting
same problem here
Thank you very much for your suggestions.
I forgot to request you include the ability to update firmware for the NsPanel Pros remotely through ewelink, please.
This is a good idea. We have done it for ZBBridge-U, so there is nothing holding us from doing it for NSPanel Pro. We should be able to add this feature in November or December (Both NSPanel Pro and eWeLink App need an update to support it).
And going forward, I recommend all devices should have a reboot funceature . The addition of rebooting feature in the NsPros is a great feature and is worth Replicating in all Sonoff devices.
I agree. I’ll pass this feature request to SONOFF’s product managers. By the way, ZBBridge-U already has it.
Hi, could you please submit a log through your NSPanel Pro? Also, have you noticed whether the external temperature/humidity source for the TRV actually stops working when it prompts that the source is disconnected?
Hi, could you please submit a log through your NSPanel Pro? You can find them in Settings > About.
done, Thank you!
Hello.
You can also add a testing device: 1002201eed
Good morning,
could you please add my ID: 10025b2d63 for v4.0.x firmware.
Thank you very much.
yes, it stops working until it reconnects.
Hi, unfortunately, the problems related to external sensors on thermostatic valves continue with version 4.0.7. This is a major problem given the arrival of winter… I ask you to kindly apply a patch for this issue.
Thank you.
@filip.andrzejczak @sliftspb Hi, the firmware has been deployed for your devices. Please navigate to Settings -> About to check the update. Please let us know if you met any issue.
Having a lot of zigbee disconnects and binding issues moving from 3.x.x to 4.0.7 in home assistant with zigbee2mqtt. Anyone else?
We have started to investigate the issue yesterday. Don’t worry, it’s not a big issue. I’m sure we could fix it soon.
