NSPanel Pro V4.0.7 Optimized Version Released
Hi Roberto:
Is the update issue solved? We have just released v4.0.12 firmware. If you check the update through Settings -> About -> System Update on your NSPanel Pro, you should be able to download and install the latest firmware.
Please let me know if you met any issue.
Hi, thank you very much for the reminder. We are developing this simple web tool which should be online on November 4th. We hope this tool could significantly simplify the process of joining the NSPanel Pro Beta Test program.
Unfortunately on my device still 3.12.0, When I press software update, checked pops up and that’s it.
@MichaelLearnsToCode Unable to install version 4.0.12 on nspanel pro 86. Memory error occurs.
Good moorning Michael,
unlikely I don’t have good news. Any time I try to upgrade my panel installation is aborted and doesn’t go over 3.9.4 Version for OS and 3.12.0 for App Version.
It’s seem to be some error on /cache/recovery/block.map file that block the installation of the upgrades.
So i decided to send back the panel to my seller.
Thank you very much for your helps.
Roberto
hi, it doesn’t offer me an update to 4.0.12 on my nspanel pro120, but I already have 4.0.12 installed on my nspanel pro80.
NSpanel pro120 od code :100265651a
Updated to new version all okay, when I open F-droid there is an update available, should I update? Cheers Luke
Same issue here. Solves by restarting, unplugging from power outlet, … finaly it installed OK.
But termostat is still a mess. Does not operate actuator correctly. It stops heating, but does not turn actuator (TH Origin) off. Once disabled, does not turn heating off.
Same - no updates available
Hi please add white list my nspanel pro
Id 1002609a08
Hi, it seems your NSPanel Pro has lots of stuff in it, so the internal flash memory is not enough for a new update. v4.0.12 firmware is indeed much bigger than previous version.
Did you install many Apps or are you just using NSPanel Pro App? Currently I could think of 3 possible solutions:
  1. Remove some of these Apps to get more free flash memory space.
  2. Install File Manager App to manually delete unnecessary files. You could use Fossify File Manager, Amaze File Manager, or Material Files.
  3. Do a factory reset to clear all user data.
We are also working on other better solutions now.
Can you please enroll my DeviceID: 10023a76a8
Is 8gb emc memory enough for an update?
I don’t have any apps installed. I solved the problem by choosing method 3. I performed a factory reset. Now the update to version 4.0.12 was successful.
Hi there, I would like to test the 4.x.x version on 100251d488
Thanks in advance
No update for me,…
Thank you. Sadly i still don’t get the update. It tells me that i am on the latest version (3.12.0). I reset the device but still no luck.
HI. Please Give me last update for NSPanel Pro 120. My device id 100250c835
Thank You
Hi, I would like to test the new firware, ID:10025b2ca2, thanks a lot!!
Since some time (I didn’t check firmware version) the RTSP cameras which i could launch on nspanel are not recognized anymore.
Am I the only one to have this problem ?
