NSPanel Pro Roadmap and Co-Created Future
Hi, here are the steps to use NSPanel Pro as a Home Assistant voice assistant:
Prerequisites:
  • SONOFF Dongle M running Home Assistant (any working HAOS environment is fine)
  • Install the Home Assistant App on NSPanel Pro via F-Droid
Configuration:
  1. Install and start the Whisper add-on.
    Go to the Voice Assistant settings and configure STT by selecting “faster-whisper”.
    (If this is not selected, you will only be able to control devices through the text input dialog instead of voice commands.)
  2. Install and start Piper.
    Set TTS to “Wyoming Piper”.
    (If this is not configured, NSPanel Pro will only return text responses and will not provide voice feedback for commands.)
  3. On NSPanel Pro:
    Apps → Companion App → Assist for Android
    Set Home Assistant as the default Assistant, then enable the wake word.
    After that, you can use voice commands directly on NSPanel Pro to control your devices.
Note:
Since NSPanel Pro is not a professional smart speaker device, the microphone pickup quality may not be as good as dedicated voice assistants.
I’ve also attached some screenshots of the setup process to help you find the correct settings pages.
Of course! It wasn’t designed for this purpose at all. If I can stand in front of the display and ask “what is the temperature in the bedroom” and I get an answer instead of swiping through cards, that is perfect.
Your tutorial is awesome, thank you for this!
Thanks for the guide but I don’t have “assist for Android” on my NSPANEL. I don’t have assist for Android on the Companion app. How can I get it?
Hi, You can check whether your current Home Assistant version supports this feature, or if any configuration file changes have blocked it. My guess is that this might be related to the Home Assistant version or configuration file, since this page is not affected by NSPanel Pro.
I, now i update Companion App and It Is ok. Thank you
I have a NS120 pro and a CAM-PT2. Which works when I add it to a screen, but only when it is not asleep.
I can wake the CAM-PT2 up with the android app, but not with this panel.
Known bug, or still to be implemented?
Could you please clarify if you mean that when the camera is in sleep mode, it cannot be woken up from NSPanel Pro? For example, are you referring to the wake-up button shown in the app screenshot below?
