NSPANEL PRO: Issues on latest update to v4.10.0
Hello, i had noticed after i updated to v4.10.0 , on both of my NSPanel Pro 120 and NSPanel Pro Gen2, the option to set Home Assistant as HOME APP doesn’t work anymore. When the device is rebooted the Home Assistant app doesn’t start anymore.
Later update: On NSPanel Pro 120, i had uninstalled home assistant app, and installed it again and set it up again as Home app and it works after reboot. But this method did not worked on the NSPanel Pro Gen2.
LATER LATER UPDATE: it’s the home assistant app that’s crashing on start actually, not the home app setting. I have latest Home assistant from f-droid 2026.11.1-minimal. This works perfectly on the older NSPanel Pro 120
Had some success here: NSPPanelPro what is the newest firmware avaialble? Homeassistant app laggy and not starting properly - #13 by belrik
