Unable to exit Home Assistant App
Running NSPanel Pro 120 - v4.1.5 with the Home Assistant F-DROID app to automatically start on boot. This all works perfectly, however i’m unable to exit the app and get back to the nspanel interface or panel settings.
I’ve tried swiping down from the top (and every side) but no joy. Any ideas?
Yes, in the ewelink options it is possible to display the accessibility button which allows you to exit Home Assistant :
How would i go about doing this? - From the app?, it shows it’s offline. I think it’s cause the Sonoff Launcher has not started.
yes, in the app
App doesnt see the panel anymore. Seems that the sonoff software has not booted behind the scenes and just boots only HomeAssistant’s app
Anyone know how to factory reset the device with no access via app or settings? - is there a like power cycle 3 times thing?
Go to the Home Assistant settings (in Sonoff), scroll down and you’ll see an option “Allow as home screen app”, if it’s not checked, check it and below you’ll have a new option “Change home screen app” and there, if it’s not already selected, choose “nspanel pro”.
Note that I’m referring to the settings in Home Assistant, not those in Sonoff.
Thank you so much! that worked perfect
I had a problem yesterday when activating this option and I lost access to my Zigbee devices, which is why I was aware of it, it was still very new to me :sweat_smile:
