Home Assistant App won't load since 4.7.0
Home Assistant has always been sluggish but generally I could get it to work.
But since 4.7.0, all I get is the initial splash screen for home assistant and a spinning icon when trying to start the app.
Nothing else has changed.
I had the same problem - then I updated the HA App throught the F-Droid App. This made HA work again for me.
Hi, has your issue been resolved? I tested it with the latest version of Home Assistant and did not encounter any problems. Please try updating Home Assistant to the latest version and test it again.
If the issue still occurs, please record a video showing the problem and send it to me separately so I can better understand the exact situation.
Updating trough the F-Droid app brought it back to life. Haven’t tested much more than that yet.
Thanks.
I’m now running app version 4.8. The latest updated FDROID and Home Assistant. Things have been nothing but constant trouble. The NSPanelPro 120 keeps loosing the wifi. The router is about 4 feet away. All other appliances are perfectly fine with the wifi. Only the NSPanel seems to be having trouble. I set everything up with wifi and passwords etc. and home assistant is running fine. Then the next day, the wifi is disconnected and the Home Assistant app says that it can’t find the server.
Sorry for the late reply. Could you please submit the NSPanel Pro logs as soon as possible after the issue occurs?
You can submit them by going to:
Swipe down on the screen → Settings → About → Feedback → Submit
We’ll review the logs to further determine the cause of the issue.
I uploaded my logs, and everything has been working perfectly for a week. Coincidence? Yes. But I’ll take it.
I suspect the issue may be related to your network environment. No worries—if it happens again, please submit the logs directly from the panel and let me know. I’ll review them to identify the exact cause.
