NSPPanelPro what is the newest firmware avaialble? Homeassistant app laggy and not starting properly
Hi everyone,
I have an NSPanel Pro 120 (gen1) and 86 (gen2) and I’m trying to figure out whether my issues are related to the firmware version.
  • @milk: What is currently the latest firmware available for both generations of NSPanel Pro?
  • Is anyone experiencing problems with the Home Assistant app being very laggy, slow to respond, or sometimes not starting properly at all, especially after a device reboot? The problem started with version 2026.8 and also with the newest 2026.11.1 from F-Droid.
  • Have you found any fixes, workarounds, or settings that improved performance?
  • Especially on the Generation 1 display, despite being set to the dark scheme, the app is often opening with the light theme.
Any feedback on your firmware version and experience would be greatly appreciated. Thanks! :blush:
Hi, I’ll reply to your questions one by one.
At the moment, the latest firmware version for and NSPanel Pro Gen2 is 4.9.2, NSPanel Pro 86 is V4.9.5, while the latest version for NSPanel Pro 120 is V4.9.3. All three models are planned to receive the unified V4.10.0 update in November.
We have also received similar feedback from some users. After further investigation, we reported several related issues to the Home Assistant team. They confirmed that a card memory leak issue was fixed in Home Assistant Core 2026.10, which may help with lag or performance issues during use. You can try upgrading to the latest Home Assistant version first and see whether the issue improves.
Regarding the theme color issue, do you mean that every time you open the Home Assistant app on NSPanel Pro, the theme color is no longer the one you previously set?
Also, during this time, has the Home Assistant app on NSPanel Pro restarted? And if you access Home Assistant from your phone, is the theme color displayed correctly there?
OK unfortunately my Gen 2 is stuck at 4.9.2… probably becausee it is in the beta channel like it was in the past already. I will try to remove and check again for updates.
Regarding the laggy HA: I have the newest version of the core 2025.11.1 and supervisor 2026.10.5, the performance issue remainde the same.
Theme color issue: I have the dark setting as default and on the Gen 2 I never had issues, while the 120 gen1 is showing after a reboot the light scheme despite in the settings is set dark. Switching from dark (showing light) to light and back to dark, the problem is solved until the next reboot. However often the reboot is not leading to a working HA app, it keeps crashing, in the settings a manuale closure often helps, sometimes all data need to be erased for the HA app to get it started again. I hope my explanations are clearer now.
Clem
Once again, me: I just checked my gen 2 1002b3b2ae and it’s not enrolled in the beta, but it’s stuck at 4.9.2… could you check what the problem is, please?
thanks
Clem
Same here, stuck on 4.9.2. device ID 1002b3b34c
Sorry, I made a mistake earlier. If you’re using NSPanel Pro Gen2, then V4.9.2 is currently the latest version.
Did you change the dashboard which could cause the bad performance? I have the same issue with dark/white theme at startup. Also my nspanel pro 120 freezes somehow completely in the home assistant app. It has some old firmware. My other 86 has newest firmware and only works well with the website within sonoff app. Home assistant app is too slow. Also I don’t know if it has any bigger advantage over the website only.
I have always the news HA app installed and the newest firmware for all my NSP panels. I only use the standard automated dashboards, nothing fancy. @Milk: could you suggest us what to do? The panels are in my humble opinion not very much usable with HA in the current state.
thanks
clem
Would you be willing to try downloading a kiosk app from F-Droid, then use it to access Home Assistant and see whether the issue improves?
@Milk yes of course but why the HA app is not working properly?
best
clem
@Milk: Installed the new v4.10.0 update and Home Assistant companion app (latest version from F droid) is not starting any more, it force stops. Tried reboot, force stop app etc. Nothing helps.
In addition Power-on state is still not working: if I set relay to On after restart of panel it does not turn on and switches back to Off on ewelink config.
Submitted logs:
Home Assistant app is not starting for me either, but there is a trick: either close it fully via the app manager (Android settings), or, if that does not help, erase all data for the HA app, and then it can be set up again and used again until the next reboot. None of the displays (120 gen 1 and 81 gen 2) is very usable for me. Very much disappointed :frowning:
best
Clem
For nspanelpro gen2 I have installed freekiosk ( Releases · RushB-fr/freekiosk · GitHub ) and set this as home launcher. This kiosk app also supports MQTT for Home Assistant and once set as the launcher I have finally got good reliability, previously the latest HA app would crash on this device (works fine with my other tablets and gen1 but crashes on the nspanel gen2)
@belrik: How did you install that app? I cannot find it in F-Droid… Any help would be very much appreciated
@Milk: Which kiosk do you suggest? HA-app is really dreadful: it crashes continuously, and dashboards are very slow to react.
Clem
If the device is running a bit slowly, please try temporarily stopping Home Assistant first, then download Kiosk again and see if it can complete the download normally.
This can help rule out whether the device performance is being affected while Home Assistant is running.
@Milk i will give it a try, however the launcher belrik suggested seems to be much more interesting… did you try it? do you know how to install it?
@belrik could you please be so kind and tell me how you installed the freekiosk app? Are you satisfied with it? Is it working better than the native HA app?
thanks a lot
clem
I installed via the browser. Was not simple but I replaced the default launcher with YagniLauncher (via F-Droid) then I could use the browser to install via Github APK download.
@Milk I have tried the WebKiosk app, and I must admit it is much better than the HA-native app. Still a bit laggy, but much more usable on both NSPPro 120 and NSPPro 86 Gen2. What do you suggest for the future?
@belrik I haven’t tried the freekiosk app yet, but I am not sure it is worthwhile, as the Webkiosk seems not as bad as I had it in mind.
best
clem
Sure, whatever works for you. I wanted something open source that fed back screen on/off etc via MQTT and this is what I use on other tablets so it was easiest for me but it’s not for everyone.
