NSPanel Pro 120 - Ver. 4.0.4 Zigbee Devices Issues
Unfortunately, I’m getting the “insufficient disk space” message.
Sorry for the issue. Please refer to NSPanel Pro V4.0.12 impossible to complete update - #3 by MichaelLearnsToCode for possible solutions.
Yes it’s ok now :+1:
I have an nspanel pro, but the connection to the zigbee bridge pro gateway doesn’t work. I bought two nspanels to act as a router and a wall panel to control devices. Now remote zigbee devices have no connection because the nspanel doesn’t work in router mode.
Sorry for the issue. Is your NSPanel Pro running on v4.1.5 or v4.2.0 firmware? If not, could you please update NSPanel Pro to the latest firmware first?
Don’t worry, Zigbee Router Mode does work on NSPanel Pro. If you encounter any issue, we are here to help.
I’m currently using 4.2.0. It didn’t work on version 4.1.5 either, so I signed up for the beta version, but to no avail. All three nspanels don’t work with the latest Sonoff ZigBee Bridge Pro version 2.8.0 (ZBBridge-P). They don’t extend the range, can’t pair, and don’t appear in the app as a ZigBee router (I remember that nspanel used to be listed as a router in the eWeLink device list). I should add that one of the nspanels is 3 meters away from the gateway, so the problem is only with the software).
Hi, we sincerely apologize for this issue. Based on your description, our team has been able to reproduce the problem. We are currently investigating the root cause and will prioritize a fix as soon as it is identified. Thank you for your patience and understanding.
