Looking for RGB CCT/RGBW Controller Recommendations (eWeLink & Apple Home Compatibility)
Hi everyone,
I’m looking for advice on finding an RGB CCT or RGBW controller that works with the eWeLink app and, ideally, the Sonoff Zigbee Bridge Ultra (ZigBridge-U). If nothing is compatible, I’m open to getting a Matter-compatible hub to use the controller with both eWeLink and Apple Home.
Here’s my setup and requirements:
• Running 24V LED strips (RGB CCT or RGBW)
• The controller needs to support 24 volts and handle a decent amp rating (15–20 amps at 24V)
• Compatibility with both eWeLink and Apple Home is key
If there’s no controller for the Zigbee Bridge Ultra, I don’t mind buying a dedicated hub just for this use case.
Does anyone have recommendations for:
1. A controller that works with the Zigbee Bridge Ultra?
2. A system where the controller connects to a different hub for both platforms?
Thanks in advance for your suggestions!
Sonoff Zigbee Bridge Ultra works as a matter hub after the update.
You can use this RGBCW controller ( Zemismart ZML3 , or ZML3(CW) )
I appreciate your response, i will test it out!
The new update is the one string holding me back from using the bridge Ultra as a Ethernet connect door stopper :rofl:
Wow act as a matter hub? How? I have the 1.7.0 and only see the option to use as matter bridge :roll_eyes:
do you have the latest version of ewelink app v5.13.0 for android? IO system has not updated yet.
Are you on IOS or android?
Right now as far as i know its only avaible for Android (they say IOS update is coming end of Jan Hopefully)
I had to use a spair android phone to use it as a matter hub because my main phone is IOS
Ah I see. Yeah, I’m using IOS :grin: I need to wait then, but is a great news.
