Rgbic ws2811 ws2812 led Controller
Hello do someone know a led controller who supports EWeLink ?
I want to change the colors via app and touchscreen on the sonoff nspanel pro
The sonoff l3 pro stripes I have test it, it works but I want another system 5V 2A is too small for me
Can I pair this one ?
I too want a RGB controller that’s capable of 12v that also connects to ewelink.
Did you have any luck with the one you posted the link for?
anyone else elce know of a product that connects to Ewelink?
Z (;;? Vc c n tem** ** d mim vc f vc v. D o vc vc f vc z s vc vc e a qxxw
Take into account that for ws2812 individually addressable LEDs, the controller does not actually drive the current it only injects the signal as a data pattern on the D0 LED stripe pin. So you should be able to connect a more powerful power supply and that should not damage the controller up to certain extent.For much bigger currents, just left the USB C connector disconnected and power the other end of the light strip, so the controller will get its power back from the LED strip instead of getting it from the USB C connector.
Other alternatives for longer LED stripes if to power the LED strip in the middle so you can feed one segment to the left and the other segment to the right of where are you powering the stripe.
Hope this helps.
