NSpanel non Pro with ihost and Zigbee 3.0
Hello eWelink Users,
i am new to the sonoff product, i got the Ihost hub with nspanel non pro and zigbee 3.0 led controller.
i would like to control the Zigbee color over nspanel i cannot set this as widgets because i cant see the Zigbee device under ewelink app.
Zigbee as paired to Ihost aswell as nspanel.
i dont need to control Zigbee device over app only if there is a way to link them over ihost and be able to change colors over nspanel display.
will be glad to know how is that possible.
thank you and sorry for my bad englich :slight_smile:
Hey
NSP and iHost belong to different product lines as mentioned many times in the forum.
NSP needs eWeLink app and cloud service to work while iHost is a local smart home center, free of eWeLink cloud. That’s why they won’t work together.
If you happen to have a SmartThings hub, you can use matter to export devices to SmartThings platform and link it with eWeLink. In this case, any RGB lights and single channel switch can display on NSP.
As the NS Panel non-pro has two buttons could they not have a button trigger the next colour in a set series of broad colours. Eg. Red/orange/yellow/Green/Blue/white. And the other to cycle through brightness levels. I’m pretty sure that could be done with Node Red on the iHost if they have some experience of programming or Node Red.
