Hi everyone,
I’m having some trouble setting up my new Mini R4 with a Sonoff Remote Controller (433MHz). Here’s what I’ve tried so far:
- In the eWeLink app, I navigate to Mini R4 → Device Settings → eWeLink-Remote Sub-devices.
- I click the “+” button to add a sub-device.
- No matter which buttons I press on the remote controller, nothing happens.
I’ve tested with two different Sonoff remote controllers, but neither works.
Interestingly, I also tried adding a Sonoff SwitchMan R5W (which, as I understand, uses the same configuration method), and that worked perfectly fine.
Am I missing something, or could there be an issue with compatibility or the remotes themselves?
Any suggestions or advice would be greatly appreciated. Thanks in advance!
Best regards,
Thorben Jensen
