iHost support for NSPanel PRO router mode
You can’t because you need to swipe left or right to see anything else.
that’s not the problem, the problem is I cannot even chose anything to put it there! the integration with IHost is just not done - and I feel scammed by Sonoff like this…
There’s no integration with iHost. What would you like to achieve with your panel?
That makes everyone very upset.
I’ve bought NSPanel Pro and ihost to make everything runs local… but the integration still almost unuseful.
I suspect that two-way integration will never happen.
Is there any update about this integration? I already use NSPanel Pro with beta 4.3.0 and still cannot work with paral-sync. I read it is about API problem. Is it still or just i am not updated about something?
The paral-sync add-on is not being developed.
Zigbee devices added to Nspanel Pro are visible in IHOST through the ewelink smart home add-on. Current version of the ewelink smart home add-on (2.7.2)
very disappointed. Hiding in concept of this is local, this is cloud, while adding router mode which is work in local to cloud product. I start thinking this disability to execute customer expectation, hiding behind concept. I just really want to control Sonoff ihost devices (zigbee) from Sonoff panel called NSPanel, which work local. thats it.
I have spend days to find out, paral-sync, ewelink addon, mater bridge (yes it is possible if i change controller from my google home to nspanel, but I want both work). Nothing works
Pues yo estoy en lo mismo. Tengo dos ihost (uno parado esperando evolución) y tres NsPanelPro ( dos parados esperando evolución) y nada de nada. Quiero usar los dispositivos zigbee del ihost en el NS y mucha evolución del Ns pero no es para potenciar Ewelink sino para HA. Cuando sean capaces de sincronizar todos sus dispositivos sonoff ya avanzamos hacía HA pero parece que no se premia a los fieles con la marca. Estoy también bastante decepcionado, se ha dejado el ihost de lado sin terminar su desarrollo. No soy programador y nunca lo he necesitado para trabajar con sonoff y Ewelink pero ahora parece que voy a necesitarlo. La verdad no entiendo que camino está tomando esto pero la paciencia se acaba y quizás tenga que valorar otras opciones.
