It’s working well, but if I turn the Smart Wall Switch ON, it’s also triggering the scene, and if I try to turn the Smart Wall Switch OFF, it turns ON immediately once again:
According to the scene, it should trigger the scene ONLY when I press the button (SNZB-01) and not when I press the Smart Wall Switch.
Even with the scene OFF, when I turn the Smart Wall Switch ON, it start the scene
The scene is abnormally triggered when the control switch is turned on
We are not been able to find the issue in the logs, all triggers in the logs are acting normal.
Please reproduce the issue then upload the log again.
The scene is still triggered even after it is turned off
We have not found this problem in the logs so far, but we can see that you turned off the scene around 15:42 on the 29th, and there is no more logs related to the execution of the scene after that.
Would you mind provide a video of the scene being triggered even after it is closed?
Then again, upload the log after reproduce the problem.
At 17:37:55, I tried to turn it off, but as you can see on the log it turned ON again.
Doesn’t matter how many times I press this light switch, it insist to turn ON again.
See the video:
Then, it decided to follow a sequence of ON/OFF that it should not do!
This sequence of ON/OFF should be done only when I press the SNZB-01 and not the Light Switch.
By the way, this scene is OFF:
I’ll submit the log once again. See the log between 5.27pm and 5.53pm
Wireless button only have one status which is click.
Therefore, the scene can only remember is that current status of it is click, so when light switch is off, it fulfilled the condition…
It was executig because there was a scene on eWelink APP (on the smartphone).
After deleting the scene from the eWelink app, iHost is working as expected.
On the smartphone, the scene was: When the SNZB-01 is pressed AND the light switch is OFF, then do something...
SNZB-01 was paired to NSPanel Pro.
When I set the NSPanel Pro to work as repeater, the SNZB-01 has been removed automatically and the scene changed automatically to: When the switch is OFF, then do something...
Can anyone assist. I have a Sonoff SNZB-03P and it is set to Detection Period of 10Sec. I tried some automations on iHost to have the light ON and delay 5 Minutes to turn OFF. I would like the light to stay on while the sensor detects movement. Ie I am in the room.
In other words I would like the detection to trigger the routine to re-start the 5 minute timer every time it detects motion.
I can do this in Home Assistant but my Zigbee devices are linked to the iHost.
Any suggestion will be welcome
