iHost error when syncing
When I try to sync a POW Elite (tried 3 different unit) I get an error: “Failed, please try later”.
the logs are:
2023-05-29T15:53:25.796894211Z “firmware_version”: “1.0.7”,
2023-05-29T15:53:25.796949628Z “service_address”: “http://ihost:8321/api/v1/device/100187649e”
2023-05-29T15:53:25.796993378Z }
2023-05-29T15:53:25.797208628Z ]
2023-05-29T15:53:25.797357086Z }
2023-05-29T15:53:25.797426795Z }
2023-05-29T15:53:25.797464128Z }
2023-05-29T15:53:25.879488970Z [2023-05-29T15:53:25.870] [ERROR] total - sync device to iHost error params------------------ {
2023-05-29T15:53:25.879754095Z type: ‘INVALID_PARAMETERS’,
2023-05-29T15:53:25.879840428Z description: ‘payload error:error(err) {\n’ +
2023-05-29T15:53:25.879896428Z ‘\n’ +
2023-05-29T15:53:25.879972261Z " Assert(err, ‘Missing error’);\n" +
2023-05-29T15:53:25.880025345Z " Assert(err instanceof Error || typeof err === ‘function’, ‘Must provide a valid Error object or a function’);\n" +
2023-05-29T15:53:25.880175553Z ‘\n’ +
2023-05-29T15:53:25.880258678Z " return this.$_setFlag(‘error’, err);\n" +
2023-05-29T15:53:25.880314970Z ’ }!’
2023-05-29T15:53:25.880361636Z }
Do you update the eWeLink Smart Home addon version to the latest one?
Yes, 1.3.0 and also rebooted a couple of times.
Exactly same issue here.
POW Elite firmware version: 1.0.7
eWeLink CUBE Version: 1.6.3
ewelink/ewelink-smart-home: 1.3.0
Thanks for confirming the issue, I was starting to think I was the only one
I have the same problem
We have noticed this issue and it will be fixed in the following update.
Thx for your report.
I´ve just updated to eWeLink CUBE Version: 1.7.0 and it is fixed!!! :slight_smile:
tnx!
Unfortunately, I have the same problem!
Try update your ihost to 1.7.0
Updating to 1.7.0 I was able to sync the device, but in the Scene section there are no conditions for the power consumption, only ON/OFF state.
Even worse in Nodered there are no state available.
How are we supposed to manage scenarios/rules for POW Elite regarding power consumption?
