Ihost cube, error missing link to sync with ewelink account after reset
I have FW 2.0 on my unit now and have the problem that the unit does not have the link to synchronize my unit with the Ewelink Web.
The shown link in the manuell is missing, reseted unit to default, still missing.
Can someone let me know what I can do?
Thank You in Advance.
Ihost is a local device. It does not have the function of connecting to the ewelink cloud.
To control ewelink devices in the LAN, use the add-on (
eWeLink Smart Home)
Thank you for the Info,
I purchased the unit and when I installed it
the first Time, it had a link as you could see in the Manuel! Which I did use ton synchronise units with the could locally.
This link worked fine and it was shown in Manuell. I did update the unit with latest firmware. I had to reset the unit and used the Manuell again and I could not find the Link on the Starpage on the iHost any more.
This was the reason I posted the Problem.
Thank You again for Your Info!!
see att Printscreen
Seth Meyers Thank You GIF by Late Night with Seth Meyers
