iHost Issue Syncing Sonoff TH-Elite and TH-Origin - invalid capability
Within the current version of iHost 1.4.2, it isn’t possible to sync Sonoff TH-Origin (THR316) and TH-Elite (THR316D) devices (running on latest version 1.1.0) since it states it has an invalid capability mentioned in the sync-process.
Error looks like this:
2023-11-08T18:25:40.866919312Z [2023-11-08T18:25:40.863] [ERROR] out - sync device to iHost error params------------------ {*
2023-11-08T18:25:40.867116768Z type: ‘INVALID_PARAMETERS’,*
2023-11-08T18:25:40.867254724Z description: ‘“event.payload.endpoints[0].capabilities[3].capability” must be one of [power, toggle, brightness, color-temperature, color-rgb, percentage, motor-control, motor-reverse, startup, camera-stream, motor-clb, detect, temperature, humidity, battery, press, rssi, power-consumption, voltage, electric-current, electric-power]’*
Looking at the payload it has the following capability mentioned:
“capabilities”: [
“capability”: “power”,
“permission”: “readWrite”
“capability”: “temperature”,
“permission”: “read”,
“configuration”: {
“range”: {
“min”: -55,
“max”: 125
“capability”: “humidity”,
“capability”: “mode”,
“permission”: “readWrite”,
“name”: “thermostatMode”
“capability”: “rssi”,
This capability isn’t allowed, but what does it mean?
                        "capability": "mode",
                        "permission": "readWrite",
                        "name": "thermostatMode"
And how can I adjust the payload in this sync process? This looks like a bug. Can this being fixed on short notice? Or does anyone has an workaround?
The issue is solved. The thermostatMode can be set to manual and upgrade the ihost solves the issue. Would be nice to have an upgrade functionality from the ihost itself instead of the ewelink app.
