The update log can be viewed at Version on the Settings page, in the location pictured here
It’s working in here.
Maybe try refresh the page for couple of times?
We’ve released smart home add-on v2.5.1 to fix the problem.
Please upgrade.
@SuiKa Can you take care of this?
Absolutely.
It’s already fixed and will release in lately version.
The new version of eWeLink CUBE 2.5.0 changuelog has appeared.
Thank you very much
i confirm its working well with v2.5.1 , thank you
It only affected the scenes with door/window, motion, presence, leak and buttons in them. They are all Sonoff devices
iHost didn’t show their current state and the operation logs for them
I ended up being able to unsync/sync them, put them back into scene.
V2.5.0 [2025.03.19]
iHost V2.5.0 Now Officially Released!
To ensure a smooth experience with the new features, we strongly recommend reading the following notes before upgrading. In this update, we’ve enhanced Zigbee device compatibility by optimizing Zigbee2CUBE. Additionally, improvements have been made to Node-RED and the Matter Bridge for better performance.
New Features:
- Users can check Zigbee devices’ compatibility with Zigbee2CUBE via iHost’s Settings or Home tab
- Delayed arming/disarming is available now to add convenience and prevent false alarms.
- Expanded supported list for eligible devices in eWeLink Smart Home add-on, including :
- Micro
- RF BridgeR2
- SONOFF NSPanel
- SONOFF THR3 series
- SONOFF S40TPB/S40TPA
- SONOFF B02 Bulb
- SONOFF B05 Bulb
- SONOFF B05-BL Bulb
- SONOFF DUALR3 Lite
- SONOFF M5 Switch Series
- SONOFF POWR316D/POWR320D/POWR316/POWCT
Optimizations:
- Expanded Zigbee device compatibility with Zigbee2CUBE.
- Display current temperature of SONOFF SNZB-TRV on CAST.
- Syncing the selected devices only to other Matter platforms is now available in the Matter Bridge feature.
- eWeLink Smart Home add-on now runs on OpenAPI V2.
- Passing custom parameters is supported for “control-device” nodes in Node-RED.
- Y-axis scale in humidity graphs on CAST now adjusts based on the detected humidity range.
Bug Fixes:
- Resolved an inconsistency in power meter readings between the iHost web interface and CAST.
- Fixed some readings missing in graphs on the iHost web interface and CAST due to devices failing to report data after environmental changes.
- Fixed an issue where the unit conversion on Temperature and Humidity Sensors could occasionally be applied without requiring the physical button press for confirmation.
- Fixed a bug where the effective periods would reset after disabling and re-enabling a scene.
- Fixed a bug with the Aqara Light Sensor T1 GZCGQ11LM reporting two illuminance (in lux) values.
very slow update for POWD316D & POWR320.
1 update ~ 2 minutes… that’s realy slow. can’t use them for main total power protection by stoping a circuit(ex: cut whasing machine if main power is over 3600W).etc…
So it’s devices synced from smart-home add-on?
What kind of update?
Do you mean the update report of electric power or electric current?
Or just control delay?
Yes that is correct
Can you send us the smart-home log?
So we can pinpoint what’s wrong.
Send it via feedback or forum message will do.
Had to zip it to get it small enough to attach
(attachments)
7a72614b-6c8a-4c1d-a40d-97db848075aa.zip (3.81 MB)
A few more question:
- Except the auto scene, is the device itself working? Controllable?
- Is the auto scene has scene log? What’s the scene log shows?
- Can you share the eWeLink device id of the problematic devices?
Hello! Could you give me a picture of how you get there? I have an LED strip model L3-5M that although the Ihost detects it through eWelink Smart Docker then does not migrate the device to Google Home as if it does with others! I want to see if through this that you comment on I can achieve something. Thank you
I mean the time between reports.
2 minutes is way too long.
@SuiKa
Please display the exact temperature with the decimal value on the tile in Ihost/cast.
