What would be the way to update the Node.js version in the Homebridge/Homebridge image?
I have the Homebridge version on PROXMOX and it is relatively simple to update via the command line.
However, I saw that Homebridge itself teaches how to update NODE.JS
However, I am unable to understand a way to do this via iHost.
SuiKa
August 7, 2024, 2:10am
2
Are you using oznu/homebridge?
If so, thatâs kind of old for now.
The official image for homebridge is homebridge/homebridge.
And I just checked, its node js version is v20.15.0.
In this case, the latest version of NODE.JS is 20.16.0.
As you can see, I have a version in PROXMOX at 20.16.0.
Which I updated manually.
Thatâs why I wondered if there is a way to update NODE.JS manually.
Why is there no way to access the docker CLI on the correct iHost?
SuiKa
August 7, 2024, 6:17am
4
We donât offer any CLI for docker or iHost itself.
So from homebridgeâs documentation , all you can do is wait for a new version.
Sorry about the inconvenience, your need for CLI is noted.
Weâll take it into consideration.
This would be useful for docker. I also vote for this if it is a feature request.
Hello @Unnamedi ,
Did you successfully manage to use Proxmox with iHost?
In this case, I use proxmox in parallel with iHost.
Only for laboratory purposes!
However, I can turn the proxmox server on and off via iHost.
Thank you very much.
I didnât know that.
Thank you very much for your help!
system
Closed
August 8, 2024, 2:59am
10
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
