How to Update Node.js on iHost?
Hey everyone,
I’m trying to update Node.js on my iHost server, and I’m a bit stuck. Has anyone here done this before, and if so, could you share the steps? I want to make sure I’m not missing anything important or running into compatibility issues.
Thanks for the help!
-Primero ve a Homebridge en doker y ábrelo.
-ve a info y al lado del numero del puerto hay un cuadrado con una fecha, pulsa sobre el.
-Iras a la pagina de Homebridge, utiliza tu usuario y contraseña para entrar.
  • una vez dentro en la parte superior derecha pincha sobre los tres puntos.
  • Pincha en terminal y escribe lo siguiente y pulsa enter: hb-service update-node
*Translated from the original post:
-First go to Homebridge in doker and open it.
-Go to info and next to the port number there is a square with a date, click on it.
-You will go to the Homebridge page, use your username and password to log in.
Once inside, click on the three dots in the top right corner.
Click on terminal and type the following and press enter: hb-service update-node
Muchas gracias!
