How can i export the consumption data from my POW R2?
I am currently using 35 POW R2 as AC meters. They help me check the consumption of these 35 units. Every month I have to manually export the consumption data from the app and type it into a spreadsheet. It is tiresome. Any suggestions on doing this by batch export, or automatically?
Hi there, you can download your power monitoring devices historical data via eWeLink web, https://web.ewelink.cc/, give it a try.
Hi the last time i used the free trial to check it out; i could not download the monthly consumption data. Has this been changed?
Works great my side.
Can i use pow r2 in lan mode ? In the place where are installed no internet accesos… can i use un local mode only?
Do You have plan yo hace access via rest API like switch basic r3 DIY mode??
I need yo run only i’m local mode…
Thsnks
Hi there, Lan mode is supported by POW R2, and please refer to our developer center for open APIs.
Developer center
My issue is that i have to download dozens of CSV files, add their daily consumption, and report it in the spreadsheet we use. It’s mad.
Can we get a dashboard with monthly consumption per meter directly from the server? I mention from the server because currently historical consumption data is still stored on each devices, meaning we are dependent on each device being reachable at that given moment (which it often isn’t, either because of device, network, or server issues). I would be glad to pay MORE to not have to do this.
