eWeLink CUBE won't pull firmware update for TRVZB
Hey, sure, here is the file:
index.json (414.8 KB)
What do you want me to visit that website with?
Hello
For me the same thing on 7 TRVZB:
-2 are in 1.2.1
-2 are in 1.1.5
-3 are in 1.1.1
When I delete a TRVZB in 1.1.1 on ihost and I pair it on a ZBBridge-U or a ZBBridge-P, it is recognized in 1.1.5 and it is possible to update to 1.2.1.
When I return to ihost and integrate it with eWeLink Smart Home, it has version 1.2.1.
But as soon as I want to associate it directly on the ihost its version is in 1.1.1
I absolutely want to separate myself from eWeLink Smart Home and I need my TRVZB to be synchronized with one of my SNZB-02D.
When will the solution be available?
Thank you
Patrice, I have 19 TRVZBs at v1.1.5 connected directly to iHost. If I reconnected them to a ZBBridge to do the update to v1.2.1, are you saying the iHost will see them as v.1.1.1 when I re-pair them.
I won’t try it, to avoid this problem.
I prefer it to stay in 1.1.5 for now on ihost, that’s why I tried on a 1.1.1
On 19 you can try on 1…
browser or other download tools :slightly_smiling_face:
On the computer used to access the iHost? I thought maybe I could install a browser on the iHost as a docker image or something?
Just a regular client on your lan should be fine;
Do you want the whole thing or just the bit about the TRVZB? I can get just the TRVZB part with just this phone.
This is just the TRVZB bit
full file
zbupdate.txt (848.9 KB)
I updated one of my TRYZBs (at v1.1.5) on a ZBBridge-P to V1.2.1 and confirmed the update was successful. When I re-paired to the Ihost it’s showing as v1.1.5. Rebooted the iHost and still showing V1.1.5. Re-paired to ZBBridge-P and it’s showing as v1.2.1.
11 TRVZBs here with an iHost on CUBE 2.4.0. All were “up to date” on firmware 1.1.5 according to iHost prior to me reading this thread. Clicking on the JSON above in the browser of the computer on the LAN that I normally use to control the iHost results in a long icon-spinning delay when I “Check for updates” on one of the TRVs, but nothing eventually happens and the TRVs stick on 1.1.5
Ihost is not finding any ota updates.
Does not find updates for devices: ZBMINIR2, SNZB-02D. TRVZB.
@ward Is ihost connecting to the correct github address?
I updated the SNZB-02D to version 2.2.0 using nspanel pro.
After reconnecting the SNZB-02D sensor to the ihost. The ihost still shows the old version
I did a bit of investigating in the logs. There’s an interesting error in aibridge_cube.log just as I press the “Check for updates” button on a TRVZB that has been factory reset back to firmware 1.1.1. Looks like the .json file doesn’t download properly and so no OTA update takes place.
[32m[2024-12-08T12:21:25.756Z] [INFO] default -e[39m [ota] onmessage <========== ota/device/zigbee/0cae5ffffeae9993/check {} 2
e[32m[2024-12-08T12:21:25.758Z] [INFO] default -e[39m [ota] 0x0cae5ffffeae9993 because Check Request add to ota check queue.
e[32m[2024-12-08T12:21:25.758Z] [INFO] default -e[39m [ota] 0cae5ffffeae9993 ota check. support ota ? true, support models? true
e[32m[2024-12-08T12:21:28.743Z] [INFO] default -e[39m publish ota mqtt bridge/system/http/request {
url: ‘https://github.com/Koenkk/zigbee-OTA/raw/master/index.json’,
type: ‘json’,
method: ‘GET’,
module: ‘ota’
} {} 1733660488743
e[32m[2024-12-08T12:21:29.232Z] [INFO] default -e[39m [ota] onmessage <========== bridge/system/http/response 1404555
e[91m[2024-12-08T12:21:29.352Z] [ERROR] default -e[39m get image meta error: https://github.com/Koenkk/zigbee-OTA/raw/master/index.json need array, receive object
e[32m[2024-12-08T12:21:29.353Z] [INFO] default -e[39m set new cache: {
ota: { available: false, currentFileVersion: 4357, otaFileVersion: 4357 }
e[32m[2024-12-08T12:21:29.355Z] [INFO] default -e[39m publish ota mqtt ota/device/zigbee/0cae5ffffeae9993/check-result {
available: false,
otaFileVersion: 4357,
isSuccess: true
} {} undefined
e[32m[2024-12-08T12:21:29.357Z] [INFO] default -e[39m publish ota mqtt ota/device/zigbee/0cae5ffffeae9993/check-state { available: false, currentFileVersion: 4357, otaFileVersion: 4357 } {} undefined
e[32m[2024-12-08T12:21:29.358Z] [INFO] default -e[39m [ota] before remove : 1 Check Request
e[32m[2024-12-08T12:21:29.358Z] [INFO] default -e[39m [ota] after remove : 0
Hey, any news here or some ETA?
@here
Hey all,
We’ve identified an issue with TRVZB and plan to patch it in the next version, estimated to arrive by the end of this month.
@ward, is it an iHost software fix or TRVZB firmware fix ?
It’s iHost
Is the patch going to fix OTA updates in general for iHost?
I have an Ikea button that keeps failing to update
