eWeLink CUBE 1.5 update problem
After updating my iHost to 1.5, I lost control over individual channels on my Aqara H1 switch. I can still control on/off for both channels but changing the state of just one ends up in a failure. I tried to remove and add the device, but it did not help. It used to work on 1.4, any tips how to make it work?
:rofl: I also encountered a similar problem, I guess there is some bug in the code…hope there will be a patch version soon to fix this
The team just deployed 1.5.3 hotfix which fixed the problem. Thank you so much dev team :+1:
