♨ eWeLink CAST Updates: V2.20 on May 20 - more devices supported
cast ewelink logo
Note: Minimum version of webview required is 49, if the CAST page does not load normally, please try to update your Android OS/iOS version.
If you have any suggestions or ideas, please feel free to leave a comment.
V2.20 (2025.05.12)
  • More devices supported:
    ‒ SONOFF camera CAM-PT2
    ‒ SONOFF switch DUAL-RBS
  • Improvements
    ‒ Optimized the display of channel names for multi-channel devices
    ‒ Improved the tile design for the SONOFF Cam Slim Gen2 cameras
V2.16-2.19 what's new
V2.19 (2025.04.09)
    ‒ eWeLink Curtain
    ‒ eWeLink virtual device, including virtual button and virtual switch
V2.18 (2025.03.06)
    ‒ SONOFF SNZB-02D Zigbee Smart Temp&Hum Sensor
    ‒ SONOFF NSPanel Pro 120
  • You can now customize NSPanel with a larger size, displaying temperature and humidity readings.
V2.17 (2025.1.16)
‒ SONOFF camera CAM-S2 is supported
‒ You can now customize single-channel device tiles with a larger size.
‒ TRV now displays current temperature
V2.16 (2024.12.17)
  • Device Supported: SONOFF ZBM5 / ZBBridge-U
  • Gateway devices will now show security alerts
  • Optimized the data display of some temperature and humidity sensors
V2.11-2.15 what's new
V2.15 (2024.11.12)
CAST appearance now supports following your system’s light or dark mode setting.
V2.14 (2024.09.13)
  • Supports switching between two tile sizes for the Zigbee TVOC Air Quality Monitor on CAST.
  • You can now use a light or dark apperance on CAST (WEB - CAST menu - Edit).
V2.13 (2024.08.21)
  • Support multiple tile sizes for SONOS Speakers on CAST.
  • Now all sub-devices on device selection page are listed under the selected Matter Bridge.
  • CAST Preview page now supports removing the selected tiles of devices, groups, and scenes.
V2.12 (2024.07.17)
  • Cameras added to eWeLink via eWeLink CamSync (camera gateway) are supported.
  • Optimized CAST configuration page UI design for better user experience.
  • Sorting of the device selection list has been optimized.
  • Now the sub-device on device selection page displays the name of the gateway it belongs to.
  • Two new preset backgrounds are available.
V2.11 (2024.06.20)
  • New widget “Scene Logs” is available, displaying the last 30 logs.
  • New Extended layout allows you to place more tiles in a row.
  • New feature Custom Background allows you to use images as backgrounds. tips
  • Now you can create up to 10 CAST Dashboards.
  • Clock widget now supports switching between 12h and 24h
Video:
https://youtu.be/LPC93dc-gs4?si=zrZqKXuCaKXpHAzl
V2.10 what's new
V2.10 (2024.05.16)
Newly supported devices:
  • Matter bridge
  • Matter lights
  • Matter light switches
  • More eWeLink supported sockets
V2.9 what's new
V2.9 (2024.04.01)
  • Some of the newly supported devices
    • SONOFF TX Ultimate series
    • eWeLink IoT cameras
  • Temperature & Humidity sensors now support larger tiles.
  • TRV & TX Ultimate series now supports group feature.
V2.8 what's new
V2.8 (2024.03.04)
1.New devices supported in 2 sizes of tiles:
  • Zigbee Wireless button
  • Zigbee Motion sensor
  • Zigbee Door/Window sensor
  • Zigbee Water leak sensor
  • Zigbee Thermostatic Radiator Valve
2.Devices listed above supported in 2 sizes of tiles.
3.Lighting devices now support larger tiles.
4.Scan QR code to login is available.
5.Clicking on the version number to view the release notes will open a new tab.
V2.7 what's new
V2.7 (2024.01.15)
  1. Matter switches/sockets were supported.
  2. Some of the Media Air Conditioners were supported.
  3. Camera background image optimized.
  4. The icon of the device will be synchronized with the “display as” icon set in the eWeLink App. (currently only single-channel device)
eWeLink Web: https://web.ewelink.cc/
eWeLink CAST: https://cast.ewelink.cc/
eWeLink CAST APP Update: 【Matter Devices supported】eWeLink CAST App V2.1 released
V2.6 what's new
V2.6 (2023.12.15)
  • The following device tiles support larger sizes: Wi-Fi Door contact sensors, Zigbee wireless buttons, Zigbee temperature and humidity sensors, Zigbee motion sensors, Zigbee door and window sensors, Zigbee water leak sensors.
  • Custom text tiles support code snippets embedded in iframe tags to adaptively display content.
  • Added support for RF gateway to display the number of remote controls.
V2.5 what's new
V2.5 (2023.9.20)
Note: To make sure the new version works properly, please configure your CAST on web 3.0 :
Document
  1. NSPanel Pro is supported, you can now switch security modes on CAST dashboard.
  2. Tiles for multi-channel switches have been optimized.
  3. Temperature sensors now display 1 decimal place on the tiles.
V2.4 what's new
V2.4 (2023.6.29)
  1. Tiles for multi-channel switches now have a larger size.
  2. The weather widget now shows selected unit (Celsius /Fahrenheit).
Try the new version and create your unique CAST dashboard!
eWeLink web: https://web.ewelink.cc/
eWeLink Cast: https://cast.ewelink.cc/
V2.3 what's new
V2.3 (2023.6.1)
  1. Tiles for single-channel switches now have a larger size.
  2. Weather/Calendar/Clock widget now support larger size.
  3. Weather icons optimized.
V2.2 what's new
V2.2 (2023.5.17)
1.Now you can add a time widget to your dashboard. ( a larger size will be available in next update )
2.The text widget now supports two sizes, the larger size can be used as a to-do list and you can switch the size on the settings page.
3.Temp.&Humid. sensors with screens like SNZB-02D are supported now.
V2.1 what's new
V2.1 (2023.5.05)
New features:
  • Text Widget
Now you can create text widgets and use them as titles or reminders.
  • Group Control
The groups you created in eWeLink app can now be added to Cast dashboard.
V2.0 what's new
V2.0 Released on 2023.4.17
V2.0 (2023.4.17)
We have optimized the scene, weather, and calendar tiles to offer a more flexible arrangement, now you can drag & drop every tile into any desired location, and spaces are allowed between tiles.
We’ve also optimized the preview feature, when configuring a dashboard, background color changes will now be shown in real time, what you see is what you get.
V1.8 what's new
V1.8 Released on 2023.3.30
V1.8 (2023.3.30)
eWeLink Cast V1.8 is released, now all users can create and view dashboards!
With the simple and intuitive interface of Cast, you can easily create dashboards, add and organize your devices, and monitor your home’s energy usage.
While some features are limited for non-VIP users, you can still use eWeLink Cast to create your own smart home dashboards, change the background color, view the weather forecast, and check real-time device status. And if you decide to upgrade to the Advanced Plan, you’ll unlock full device control on both eWeLink Cast and eWeLink web, and even more advanced features.
Besides, in this update, the following Zigbee sub devices are supported:
Zigbee single channel switch
Zigbee single channel plug
Zigbee Cold/Warm light
Zigbee RGB/Cold/Warm light
Zigbee (3.0) 1~4 channel switch
Don’t miss out on this amazing opportunity to try the eWeLink Cast, visit eWeLink web and navigate to the CAST menu to try it out!
V1.7 what's new
V1.7 Released on 2023.3.1
V1.7 (2023.3.1)
Firstly the update includes an optimization for SONOFF TH10/16, which can now display data charts, this is a great way to keep track of the temperature and humidity levels in your home or office and make adjustments accordingly.
(Note: Will be effective after a patch on March 2 )
And now Cast supports even more devices including:
  • eWeLink supported Water Leak Sensor.
  • SONOFF SPM-4Relay,with data chart.
  • SONOFF DW2-WiFi (new edition).
  • Some dimmer switches, GSM switches, and Zigbee lights.
As most of the devices supported by eWeLink are integrated, you can now easily control and manage your devices from the centralized Cast dashboard.
Overall, eWeLink Cast is becoming more and more powerful with each update, and we highly recommend checking it out if you haven’t already.
V1.6 what's new
V1.6 Released on 2023.1.11
eWeLink Cast has been updated to version 1.6 with the following updates.
  • eWeLink Camera App is supported, now you can view the live stream of eWeLink Camera App on dashboard.
  • More switches have been supported.
  • Now the chart darkens if the device goes offline.
  • Add tips to the chart selection settings on the settings page.
V1.5 what's new
V1.5 Released on 2022.12.24
eWeLink Cast has been updated to version 1.5 with the following updates.
Devices Supported
  • eWeLink Cameras (SONOFF GK-200MP2-B/Cam Slim, etc.)
  • eWeLink Light Strips (SONOFF L2/L3/L3Pro, etc.)
  • eWeLink smart switch SONOFF DUAL R3 Lite
  • Some Yeelight smart lights
New features
  • Dashboards can be sorted on settings page.
  • Now you can watch the camera’s live stream on Cast dashboard.
  • 2-channel power monitoring devices now can show the charts of both 2 channels. (SONOFF DUAL R3)
Features Optimization
  • Light controller added ON/OFF button
  • Scene button added animation effects
  • Layout optimized
V1.4 what's new
V1.4 Released on 2022.12.01
We have updated eWeLink Cast to version 1.4 and included some new features.
New features
  • Firstly, changing the color of background is available now, you can select between four preset colors.
  • Temperatue & Humidity data chart is now available.
(And now some of the power monitoring devices support the display of hourly views)
animate
  • Charts display is now customizable, on the settings page, you can choose whether to display the device’s chart.
Devices supported
  • SONOFF POWR3 smart switch, Power Consumption chart supported.
  • SONOFF S40 smart plug, Power Consumption chart supported.
  • SONOFF TH series, Temperatue&Humidity chart supported.
  • eWeLink Zigbee Wireless button, status & history supported.
  • Some Zigbee lights are supported.
  • Lights synced from Home Assistant are supported.
Feature optimization
  • PIN code optimized, now it is required when you exit the encrypted dashboard.
  • History of sensors optimized, now showing 7 days of history.
  • Other UI optimizations.
V1.3 what's new
V1.3 Released on 2022.11.03
We have updated eWeLink Cast to version 1.3 and included some new features.
(check this video for quick overview: https://youtu.be/pjwfGxfQ2aI)
First, we’ve changed the color of Cast dashboard to a warm one, hope you like it.
(We plan to add the ability to change the background, which has not yet been implemented.)
Added support for the following devices:
  • SONOFF DUAL R3, in previous version Cast supports only Switch Mode, now the Motor Mode and Meter Mode are supported also. You can control your roller shutter right on the Cast dashboard now.
  • eWeLink curtains. Now you can control your curtains/blinds on the Cast dashboard.
New features added:
  • Calendar & Weather widget: Check time, date and recent weather right on the dashboard.
  • Energy Consumption Chart for power monitoring devices: Quickly view the last 7 days of electricity usage.
  • Device icon changeable: Change the icon of your 1-way switch in the eWeLink app and the change will be synced to the Cast dashboard. (In the app, go to device settings, select Display As, currently only 1-channel switch supported)
  • Release note: Added version number to the home page of Cast, click it to view the release note.
Feature optimization:
We have optimized the UI controls for light devices, you can now also drag the brightness bar on the computer web page to dim the light, just like on the tablet.
Nice would be a integration of eWeLink Camera. Like to have a widget of a camera to see if someone is at the door. :v:
The camera is on our to-do list :grinning:
It would be nice to have some basic CSS/Styling options…?
This may require a certain level of user expertise, will discuss with our R&D, maybe in the future.
In the short term we will add the feature of modifying the background. :grinning:
I recently bought plug + meter (https://s.click.aliexpress.com/e/_DlAFfOF) ( Ewelink-enchufe inteligente con Bluetooth y WIFI, dispositivo con temporizador de 16A, con Monitor de potencia, funciona con Alexa y Google Home) And it works perfectly with eWelink android app, also creating scenes.
But from Web.ewelink can’t see these devices neither create scene or even include this device in any Webhook scene.
Are you planning to support it?
Hi, this device is expected to be supported by eWeLink web scene&webhook next month, around the 9th Nov.
Ciao, avrei due domande da fare:
  1. come mai non riesco ad aggiungere il grafico dei consumi energia?
  2. il sonoff dual r3 in modalità motore anche se spento l’icona risulta accesa, sarebbe più opportuno che l’icona fosse spenta.
    grazie
Ciao, per la tua domanda:
  1. per ora il grafico del consumo energetico supporta solo alcuni dispositivi, più dispositivi saranno supportati nella prossima versione entro questo mese.
  2. grazie per il tuo feedback, valuteremo la possibilità di ottimizzarlo.
Please add support for dualr3 lite
Thank you
Hi, is it possible to add the following things?
  • possibility to sort the auto scènes
  • possibility to sort triggers and actions commandos for auto scènes , if you want to ad for example a commando between al ready programmed commando’s, it’s not possible
  • possibility to ad delays for hours in auto scènes (the max now is 59 minutes)
It’s on our to-do list, will be supported soon.
Unfortunately, Auto scenes will not be supported in CAST, the CAST is designed as a dashboard for quick control but the auto scenes are run without any touch, sort them in the APP or Web is recommended.
Hi,
If you’re asking about Cast, the auto scenes won’t be added to the Cast.
If you’re asking about the App scene feature:
  1. the auto scenes sorting feature will be supported in mid December
  2. for the triggers, if you set ‘any conditions is met’ then the sorting feature does not make sense.
    if you set ‘all conditions are met’ ,then the sorting feature does not make sense either.
    for the actions, the action will be executed one by one, wen have no plan for the sorting, we suggest to add actions in order according to your needs.
  3. Currently no plans, it may be inaccurate if it takes too long.
Hi,
When will the Elite range of devices be available, my older devices now show temp and Hum thank you.
Great improvement! Love it!
and when we can expect consolidated energy spending report on dashboard, not only device-by-device?
in next version, expected to release in early December
hi, we’re considering this, it may take some time, perhaps after one or two release.
Hi!!
Is it already supported?
thank you in advance…
