I have a problem with the zigbee sensor SnZb 04, in detail I manage the sensor with smartthing, and until three day ago all was ok, from to day, more or less, the sensor running in ewelink ma not running i. Smartthing. The other same three sensor running correctly. Only this sensor is frozen!.. but if I refresh in manualy mode the ewelink inside the smartthing immediatly working!
Pleaee help me
Hi there,
“frozen” do you mean this device can’t be controlled in the SmartThings app?
Please try to re-link the eWeLink service in the SmartThings app.
Hi, thank you for your feedback… try to reconnect the servire but the problem is present in one sensor only…tre snbz04. Smartthings and alexa too do not see the sensor…only this and I do not understand why!.. i think the problem is in the ewelink when sends the status in exsternal apps…do you have an idea to solving this problem? Thank you
Would you please send the device ID?
a4800236f6, this is the Id,
Thank you dor your courtesy…
Hi there,
Please submit a support ticket via in-app “Help & Feedback”, then the tech engineer can look into the logs.
ok …done…thank you very much!
This may or may not help, but as a plane user with two devices they have rubbish battery holders and need a redesign. The same method is not used in the motion sensors, temperature sensors or the button. Before doing anything complicated try just replacing the battery if it was low and squashing the battery holder. You may find that just that will solve the problem. If mine disappear again I am going to add a bit of cardboard but at present it is all okay.
hello, thanks for the advice, I tried as you told me, I also reinstalled the sensor and re-paired smartthing, let’s see if it works! I don’t understand why only one sensor doesn’t work, while the other 4 do…
A distanza di 2 anni ho lo stesso problema con un altro sensore…provo a mettere lo spessore e a sostituire la batteria
I had same issue.
Sometimes they become offline, sometimes they come back by themselves, sometimes I need to replace the battery (even iHost showing the battery level higher than 75%)
I lost my patience and I replaced it by the newer version
Ciao, la versione più recente? Quale? E… dopo non hai avuto più problemi? Grazie per l’aiuto!
This is the most recent version: SNZB-04P
