Hi
Years ago I bought the device “DM-583” took it today out of the box and it works very well. My main problem is a missing function as a button or pushbutton instead of a switch.
Could this be added in any way to the eWe software please?
Doesn’t matter that it takes one second to switch but no longer than 3 seconds between the off-on-off please!
By hand this is possible
Push manual on then again and it turns from off -push- on -push- off in around 1.5 seconds.
Kind regards and thanks for helping!
I also need this!
So i Used the App but it is a dirty workaround @heitorbadotti2
Go to “Scene”
Press the + Button upper right corner
If → Add choose something like “Tap to perform”
Then → Smart Device → (choose your) DM-583 → ON → (upper right corner) Save
Then Hit the plus button next to “Then”
Choose Delay 01 second
Press Save
Then Hit the plus button next to “Then” → Smart Device → (choose your) DM-583 → OFF → (upper right corner) Save
Now press Save again
Give it a Scene Name like “Pushbutton”
Add to Homescreen or else and you have a Pushbutton instead of a switsch!
