When restarting the Host or if the Internet goes down, the devices synced in eWeLink Smart Home go away, and to get them back you have to turn them on at the switch or via the eWelink app. As I understand it there is a big coupling here with the eWelink app and server. I had an expectation that with iHost I could run locally, but from what I’ve seen this only occurs with Zigbee devices. On the other hand, the LAN Control function has never worked here, in which case if the internet goes down I will be without operating my devices.
hi, from our test, after reboot or Internet goes down, the synced device does not affected.
What’s your iHost CUBE version? is it the latest 1.5.3?
When the Internet goes down, do all synced devices fail, or some of them? Would be better if you can provide more device info.
Indeed there were some compatible issues with some TF cards, we’re working on fixing the issues and will release an update several days later, before the update, you can try to remove the card, reboot iHost and insert the card again to see if it works, sorry for the trouble.
Hi, please try to re-install the add-on to see if it works
I reinstalled several times
it installs correctly but does not display the devices
I can confirm that this issue is still reproducible on iHost latest FW 1.10.1. When restarted, some of the devices are shown as offline, and only appear online if i toggle them in their reverse state. Also there is an issue where few basicr2 devices are not registered at all even though they are in my network for months
Please use the mdns tool to check if the basicr2 device exists in the LAN network
What specific devices do you mean when some devices are offline? Can you provide the deviceid of these offline devices? In addition, you can upload the logs of the eWeLink add-on through the feedback button on the iHost settings page to help us troubleshoot the problem.
