Devices are not correctly added to the app
After the last ihost update, the device’s connection to the ewelink app is working strangely.
The ihost device itself is online in the app,
but all its child devices are offline.
However, when I configure them on NSPanel PRO, it sees and allows me to configure them, and they work perfectly.
Additionally, the devices are visible under the gray background and display correct data.
Please refer to the attached photos. I hope this issue will be resolved soon.
CUBE Ver: 2.7.0
Hi, thank you for using iHost.
First of all, the iHost Open Source Project section of this forum is intended to discuss issues and ideas around running other Smart Home Platforms (such as Home Assistant) on iHost hardware, not eWeLink CUBE OS.
Secondly, eWeLink CUBE OS on iHost won’t connect to eWeLink Cloud platform, so it won’t show up in eWeLink App. If you update CUBE OS to the latest version, you’ll see that iHost is always offline in eWeLink App. My colleague who is in charge of eWeLink CUBE OS is planning to add the feature of connecting to eWeLink Cloud platform back to CUBE OS, but it may take several months.
Thank you for your reply.
And I apologize for the topic in the wrong place.
I will wait for updates :slight_smile:
The problem he described @linuxtesting is related to a bug between the Matter bridge and nspanel pro.
The same problem occurs between the matter bridge in HA on IHOST and the Nspanel pro device.
Nspanel pro, as a MATTER HUB, still has problems working properly with Matter devices.
When it comes to ewelink applications, matter bridge devices are visible in the ewelink application only when you connect locally via LAN.
