Cannot see any of the temperature or humidity levels on cast dashboard
Hello, I have various sonoff TH temperature sensor switches which show up in the cast dashboard but i cannot see any of the temperature or humidity levels. It just shows them as a switch. These all show up fine on the normal ewelink dashboard, but not on the cast dashboard.
Can anyone help?
hi, Cast supports TH10/TH16 to show temperature&humidity now, TH elite&TH origin series are not supported yet, we are working on this.
Hi Teki, do you have a timeframe for TH Elite?
it is a long time ago since you mentioned that you’re working on this
Hi, it is supported,
if your device is not supported, please let me know the device id.
sorry, I’m refering to the cube local cast
It is supported on local CAST too, but no data chart.
yes I was not clear
this is what I meant, chart display of hourly/daily values for TH from a THR320D
This might be because the cast dashboard doesn’t support those specific features yet. Make sure your firmware is up-to-date, and try contacting eWeLink support for more help. They might have a solution or update that can fix this issue.
