Zigbee Bridge Ultra compatible smoke detector
Could you please let us know the exact model of the device you wish to use?
Alternatively, if possible, please provide the purchase link of the product.
This will help us verify more accurately whether the device is compatible with ZBBridge-U.
There are many on the market, but none explain compatibility with eWeLink, that’s why I’m asking, because I can’t find it.
I found one from the Heiman brand; there are three models: Zigbee, Matter, and Wave Plus. According to a comment, the Zigbee model works with eWeLink.
If the zbbridge-u accepts Matter, would this one work?
We have a simple version of a table showing which devices are supported.
You can use it to check whether the device you want is included.
It’s difficult to search by reference, and the seller information is incomplete. I found this one, but it’s not on your chart; here’s the link: HS1SA-E https://a.aliexpress.com/_EzZdnFA
We are sorry, but the HS1SA-E device is not within the compatible range. If devices from other brands or models are available in your region, you may consider purchasing alternatives such as Bosch BSD-2, Tuya, Heiman HS15A-M, HS1SA, or HS3SA/HS1SA.
Hi Jemma, I emailed Heiman and they told me that only the HS15A-M has Wi-Fi and compatibility; this model, the HS1SA, doesn’t have Wi-Fi. However, I read comments on an AliExpress page, and one person said that the HS15A-E works perfectly with Sonoff eWeLink.
Hi Jenna, the Heiman HS1SA-E works perfectly with Sonoff Zigbee and the ZB Bridge-U with the eWeLink app. Thanks.
Where can I buy it? I can’t find it. Does it work with zb pro?
Where are you from?
Czech Republic, I couldn’t find this model on Aliexpress
I sent an email to confirm the code and it’s correct: HS1SA-E, IHOMECAM Official Store €23.92. Look for this price.
