Zigbee Smoke Detector Compatibility with iHost
Hi there, I recently purchased this Smoke Detector straight forward smoke detector and it paired successfully with iHost via Zigbee protocol.
I have installed it in my garage near my solar system as an early warning in case anything catches fire.
Someone knows if he will pair with ZB Bridge Pro? Will the sensor detect cigarette smoke?
It will definitely detect cigarette smoke if it gets into the sensor.
I don’t know if it will work with ZB Bridge Pro?
I decided to buy and check out the HEIMAN HS2SA-1 device with the ZB Bridge Pro. Unfortunately, it was not possible to pair it.
