Sonoff ihost eWeLink Cube compatible smoke detectors
I cant find smoke Zigbee / Wifi smoke detector that are stated to be compatible with CUBE. Is there a list of compatible devices anywhere?
These ones work for me. Had them on ZigBee Bridge before and now on iHost. No issues. As far as I can recall ZigBee Bridge Pro was not supported.
https://a.aliexpress.com/_EyD3e8L
Hope it helps
Thanks for the help, much appreciated!
Unfortunately, the link is no longer good (maybe only for me), can you write an exact type?
BR,
Tamas
Hi. Link is fine for me. Here is it once more
eWeLink Tuya Zigbee Smart Smoke Fire Sensor Detector, Work with Tuya Hub Sonoff Zigbee Bridge, Home Assistant via Zigbee2mqtt
https://a.aliexpress.com/_EugOa83
Cannot find any specific model number, neither in description nor in the info from iHost.
Thank you very much.
(The link works at my workplace, there is something wrong at home)
BR,
Tamas
Thank you, these work.
I was able to add NodeRed whatsapp notification bot to notify if alarm triggers. It’s very simple and there’s youtube instructions.
Has anyone tested this zigbee smoke detector on ihost ?
Heiman HS1SA-E
https://www.aliexpress.com/item/1005007127577371.html
There is also a matter version, but I can’t find a store where it is available. (Heiman HS1SA-M)
I will order 1 to test!
Matter Smoke sensor is not supported, avoid it at the moment please. And it’s not stable on other platforms I have
Thanks for the info.
I wanted to test it in SmartThings.
But since you don’t recommend it, I won’t look for it for now.
Heiman sensor is working!
Hi. Do you have this zigbee version Heiman HS1SA-E?
https://nl.aliexpress.com/item/1005007127577371.html?spm=a2g0n.order_detail.order_detail_item.3.52b26d766231uE&_gl=1*13843z1*_gcl_au*OTQ2NTIwNTQwLjE3Mzc1NTc3Mzg.*_ga*NTQ3NjY2MTU2LjE3Mzc1NTc3Mzg.*_ga_VED1YSGNC7*MTczODU2MzUxOC42LjAuMTczODU2MzUxOC42MC4wLjA.&gatewayAdapt=glo2nld
Yes it is Zigbee, connected it to the iHost
I didn’t see the type number
