Two sensors for our ihost
I have tested these two sensors for the ihost and they work perfectly, water leak and fire sensor.
I leave you the link of the two sensors for those who need them.
ELEOPARD EV-WI-03
https://es.aliexpress.com/item/1005004585920492.html?spm=a2g0o.order_list.order_list_main.35.158b194dRxz3kC&gatewayAdapt=glo2esp
HEIMAN HS1SA-E
https://es.aliexpress.com/item/1005005218331060.html?spm=a2g0o.productlist.main.37.54061f0a8Zr6pB&algo_pvid=c6d8d69e-a142-4780-acb2-7ae13b60b204&algo_exp_id=c6d8d69e-a142-4780-acb2-7ae13b60b204-18&pdp_npi=4%40dis!EUR!19.58!16.05!!!21.03!!%402103835c17032774172271373e940a!12000032226916795!sea!ES!713792645!&curPageLogUid=44tkdM7N66G7
Hello the second link isnt working
Sorry they have eliminated the product on aliexpres, I leave you the product from the official website, the model would be Heiman HS1SA
is this the same product?
https://www.aliexpress.com/item/4000127376848.html?spm=a2g0o.productlist.main.7.2ea7282cCGIL1L&algo_pvid=c003b55a-e3e9-4159-949b-0f0b9140515b&algo_exp_id=c003b55a-e3e9-4159-949b-0f0b9140515b-3&pdp_npi=4%40dis!EUR!31.66!25.33!!!34.26!!%402101efeb17040127090167410e9299!12000036695524479!sea!GR!2370064355!&curPageLogUid=DWo4TuaGJIKZ
It is the HS1SA-E, HS1SA-EF I cannot say that it works, ask if you made a mistake when entering the model.
Es el HS1SA-E, HS1SA-EF no te puedo decir que funcione, pregunta si se ha equivocado al poner el modelo.
I have a random cheap one I got from Aliexpress and it works. I have a Carbon Monoxide Sensor that doesn’t and I use with Zigbee2MQTT. Even if it’s a different one and you’ve already bought it I would test in anyway. That’s already more than double what I paid.
