Zbridge Pro - allways trigger the alarm sound
Hi guys, i have they zbridge for a few year, and in the las month, Even when the alarm is disable, they zbridge trigger the alarm sound when any door sensor inform a state change.
I tried deleting all the sensor an re configure all again but it’s work fine for a few days.
When the alamr is activated works fine , pending notificacionts and triggering the alarm sound.
When it’s disable , only trigger the alarm sound and i so tired of this noise.
I’m using the Pro bridge too, from a few months. No problems with mine at all, but not using as you are. Anyway, good to know that potentially this kind of issue can happen. :+1:t2:
But any kind of idea ? Its look like a software issue…
Hi, please try long press the ZBBridge Pro reset button for 10 seconds (this will delete all sub-devices and clear the coordinator), wait for the bridge to automatically come back online, and then re-add the sub-devices.
Try this to see if it resolves your issue.
Hi Leung i try this , but it only work fine for a few days.. id like to find the final solution..
I have like 20 sub devices and i can’t re configure it once a week…
I have a NS Panel Pro and the same happened to me 1-2 weeks ago.
I fixed it by disabling and enabling the door sensors in the Alarm settings (away mode, etc)
