ZBBridge Ultra Have LAN MODE?
Because I can’t control the HUE lights with scenes, I already have them linked and see them in lan mode. But there are these problems:
*I can’t use them in scenes
*Cannot be activated outside the home
It’s strange because from smartthing I can see and run scenes with phillips HUE, and I don’t have Smartthings HUB, only through the cloud
Latest iHost docker eWeLink update 2.4.0
make possible to sync ZigBee devices connected to ZBBridge Ultra to iHost
Only ns panel and ihost work as matter hub? Why ZBBridde ultra dont, will there be an update to make it work as a matter hub? I think it is powerful enough to do it
Only Nspanel pro as matter hub.
The host only works as a matter bridge.
It may be possible to launch Matter Hub on iHost this year. But it’s not 100% certain. :thinking:
@staff
will there be an update of ZBBridge-ULTRA to make it work as a matter hub?
Hey,
There’s no plan for this feature. If you have this in mind, please create a feature request.
Hello !!! Can you please explain in detail the principle of operation of zb ultra? What functionality does it have and perhaps you can name plans for future updates?
Now it is just a bridge for Sonoff products.
I’ll see if I install Home Assistant (I already bought a mini PC)
to get more juice out of the device
Hey,
In a recent update, the bridge adds support for a wide range of IKEA devices:
  • TRETAKT plug
  • THADFRI bulb E27 WW clear 250lm LED1934G3
  • THADFRI bulb E27 WW globe 806lm LED2103G5
  • THADFRI bulb GU10 ws 345lm LED2106R3
  • THADFRI bulb E27 cws globe 806lm LED2109G6
  • THADFRI bulb GU10 cws 345lm LED1923R5
  • VALLHORN Wireless Montion Seneor
  • TRADFRI Montion Seneor
  • BADRING Water Leakage Sensor
  • VINDSTYRKA
  • THADFRI Signal Repeater
Nice. Where can we follow these updates?
How about NSPanel Pro? Is the list expanded?
For now it focuses on SONOFF and other eWeLink Supported devices. There might be something coming but I can not share more at this phase.
As there is no flood of new Sonoff products, is there anything to focus on for so long? It is probably worth looking around and adding at least the most popular ones. Such as IKEA appliances, which are available almost worldwide.
There might be more LAN features, ongoing UI optimization, as you mentioned in another topic, and better Matter support. For further inquiry about NSP Pro, please open a new topic.
