ZBBridge-P 2.3.0 Changelog missin
After the last update 2.3.0 it seemed that the device was constantly rebooting and reconnecting devices. It took several hours and the devices were often offline in the Ewelink application. I disconnected the power many times but it didn’t help. I have no idea what happened and if it’s just me.
The problem you describe has been happening to me for a long time, especially with battery-powered devices. I haven’t noticed any changes after the update.
Hi, I have sent you a message hoping that you can provide us with the device ID to locate the issue.
Hi, do you mean battery-powered devices often go offline? What devices have you added?
10017af242
a4000157e2
Got it, thanks!
I have not received any updates to 2.3.0.
I am stuck on 2.2.0
Is it worth upgrading?
Why can’t I see the update from eWelink app?
Thx
On my side, since this update, some of my scenes stopped working, mainly those with the motion sensor SNZB-03P.
Anyone having same issue?
I have a problem with scenes triggered with sensors: snzb-03, snzb-06P. Scenes don’t trigger. The problems started after the update.
I have a similar problem with SNZB-05P which becomes offline…
https://forum.ewelink.cc/t/sensor-sonoff-snzb-05p-goes-offline-and-does-not-return/
My SNZB-05P regularly goes offline… something is clearly very wrong.
Do not remove the device. Enter pairing mode and add the device again. Once detected, change the device name to exactly what it was.
Save the scenes again without making any changes.
I did as you said… time will tell if it helps. Of course it deleted all scenes associated with the sensor even though I didn’t remove the device. Sigh ![]()
Hello, the scene remains for me when he added some other device to the condition, such as a switch or a socket.
It may be due to a weak signal from your SNZB-05P. You can check the RSSI in the device settings. (Pressing the button on the device or trigger it can manually refresh the RSSI).
You can install the gateway closer or place some Zigbee router devices, such as ZBMicro, in between to enhance the signal.
RSSI Good -79 / -81dBm…
I just wonder if it was a signal problem why does the offline transition happen quite regularly after relatively the same period of time? A signal problem would rather cause quite random disconnections and for me it happens almost like clockwork. And why does it not retry the connection and instead permanently go into sleep mode?
In addition, the sensor does not wake up when I pour water on it, it wakes up and connects only when I press the pairing button.
It also seems to me that this did not happen before the pro bridge update to 2.3.0
although I am not 100% sure.
It is a pity that there are no device connection logs available in the pro bridge.
