Why can I turn on more the. One relay at a time .
Hi. Are you saying that you have interlocks enabled but can still turn on multiple channels at once?
No interlocks are not turned on. The way your info says is if you want multiple relays on, interlock can not be enabled. The green bar says Enable. It is not turned on.
Can you please record a video about it?
I got the module to work by pressing a button on the board. Why isn’t this available in the software or is it a bug.
