hello wanted to ask which sonoff can meet my needs, need a smart switch that would monitor/detect if my pc is on/off and sends/commands a 2nd Sonoff device wirelessly tp do the same on my watercooling PSU to turn it on or off located on the next room
wireless switch 1
detect if my computer (device 1) is powered on/off (trigger volt is either 3.3/5/12volts)
wireless switch 2 (relay)
turns on/off external watercooling setup (device 2) = options can turn on/off a 220v outlet to power on a PSU or can just simply connect a circuit (relay dry connection) like the pwr_on and GND on a atx PSU 24pin to start the PSU
prefered smart device that would run on 5volts
was looking at 2x RE5V1c but not sure if it can monitor a volt input as a trigger or if this would work
