Effective Period does not work when creating scenes based on temperature readings and scenes do not autostart…does anybody managed to solve this issue?
Ok i understand what you say…but i meant something else… When you set effective period like when a scene to start and stop it does not auto start on that period
Hi Mr. Gabba, you seem to know a lot about automation systems as i see that i follow the forum for a few days. How come you haven’t face these problems yet i can’t understand. The effective range startup and manual tap problem. Can you try to replicate what we are trying to success?
Basic situation: 20-21 C runs.
Time change to 18-19 C.
Time change to 20-21 C.
Scene 17-18C:
Scene 20-21C:
In the scene running the scene, another scene starts an autoscene, which is turned off by another scene… ![]()
This was also the case here (the switching temperatures have changed since then):
Hi Gabba63. Clever workaround that I hadn’t thought of. Admittedly, I am a noob.
I will give it a try.
I am using SNZB-02 T/H sensors and POWR320D power metering switch to run electric baseboard heaters.
Thank you.
