One of two auto scenes for thermostat is not working
First of all I am not sure if this is a proper place for my problem - this is my first topic here.
So I have a THR316D which measures a temperature. There are also 3 POWR320D that control a power supply for 3 heaters.
I am using automatic scenes to control a temp using the heaters.
So in a morning, everyday between 6AM and 5PM a scene turns power on if temp is below 35. This scene works with no issues.
Anothere scene checks if temp is above 37 and if so it cuts power off. This one i working and the same time/period. No issues with the scene.
Then, if ther afternoon, another scene turns heaters ON with the temp is below 45 between 5.30PM and 10.30 PM. This scene IS NOT working form a second day is was created. On a first day is has no issues.
Finally there is a 4th scene that turns power off in the afternoon if temp gets 50. This one works great as well.
So my only issue is the third scene. All the parameters are the same and the one in the morning, it just doffers with working hours and temp. Ive been testing it for a while and have no idea why it just not power up the heaters in the afternoon. Temp is usually around 35 which is lower that 45.
Any ideas? Myabe there is a way to configure it another way? I am advanced plan user.
Thanks in advance for any suggestion as this drives me crazy! :slight_smile:
regards, dr
I have the same problem with all the automatic scenes , sometime are working , sometime not, it is a mistery
I have the same issue, it seems like an unfixed bug for a long time.
Adding screenshots of the APP scene configuration that does not take effect here will help me to locate the problem.
Screenshots attached.
In the IF of the scene, the condition needs to be changed from “unmet” to “met” before the scene is triggered.
In the screenshot, the scene is not executed at 17:30-21:59, most likely because the temperature has not dropped from above 43℃ (“unmet”) to below 43℃ (“met”) during this period.
It is recommended that you add the following scene, to adjudicate it once when entering 17:30-21:59
IF(all condition is met)
Timing 17:30;
Wezownica ≤43℃
THEN
Ation 1;
Ation 2;
Ation 3
Hope it help you.
Thank you for your reply.
First of all I want to assure that the scene was not triggering with the temp far below the 43 setting. So this is not the case.
I am willing to test your suggestion but the only concern I have is how to set up end time of the scene in this case?
On the other identical scene (which works as expected before noon) I used to use effective period setting.
What is your suggestion?
The supplemental scene I gave will only be judged once at 17:30, it doesn’t require an end time to be set and it won’t interfere with the normal operation of the other scene.
Is this the scene you’re referring to?↓
If this is the scene being referred to, it could certainly be supplemented with a 6AM timed scene (similar to the one I’ve given) to serve as an auxiliary judgment, to prevent the temperature from falling below 35℃ but the room not being heated before it enters the effective time period.
