Webhook call doesn't fail if device isn't connected
Hello, I’ve created a scene with eWeLink Web advanced plan that tries to turn on a SonOff BASIC_R3 device.
When the device is powered on and connected to the wifi is connected it works correctly, but if it isn’t, it obviously can’t turn on but the webhook provides the same response as when it works correctly
{"error":0,"msg":"","data":{}}
Is it possible to get an error code in this situation?
Thank you
Hola, tengo el mismo problema, alguien sabe que puede ser o como se puede obtener el estado?
As far as I know, it is not possible to extract the state via webhook in ewelink
@ward
Yes.
We are also looking into a major update to Webhook, adding highly-requested features to it.
4-8 weeks ago if the device was not connected, a response other than “{“error”:0,“msg”:”“,“data”:{}}” was returned. But now, regardless of whether the device is connected or not, it always returns “{“error”:0,“msg”:”“,“data”:{}}”.
Please change this back to the old way.
I contacted eWelink support, they said they would forward the issue to the software team, but there is no change. This problem has been going on for almost 2 years, but it has not been taken into consideration. It is very strange that such an important issue is ignored, ewelink should have been more professional.
