TX Ultimate on / off channel led status
Hi, I would like to know if it’s possible to disable on / off indicators on channels ?, because I don’t want to show a led indicator when a channel is off
Thanks for your feedback. There is an issue with turning off the indicator light now, We will fix it as soon as possible.
In the normal setting process, you can disable the ON/OFF indicators in the Device settings by following these steps: Customize > Turn off > Click twice to uncheck.
We have identified the issue and will resolve it in the new version of the eWeLink APP. The iOS version will fix this issue in the 4.34 update by the end of this month. The Android version will address this problem in the upcoming 4.35.0 update at the beginning of next month.
