Two iHosts in two homes
I have installed a number of sonoff devices in both home and cottage. All of them are controlled by eWelink app.
I have bought two iHost devices for each of houses.
I have installed eWelink-SmartHome docker on both iHost devices.
It looks like that when logged in eWelink-SmartHome docker on one iHost, it logs off itself on the other and vice versa? Does it mean, you cannot be logged in eWelink-SmartHome docker on more then one iHost? It is problem when you control two houses with sonoff devices.
yes true , currently still not supported to use ewelink account at two ihost/mobile app at same time
Looks like that, are there plans to change that? Do you know anything, please?
It’s not likely to happen anytime soon.
Create a second account and share devices from your main account with it.
Many thanks for your support of iHost and CUBE. Our team is looking for the possibilities to lift the limit.
To finish the question. I do have two iHosts in two homes. Both logged in with same eWeLink login and it works fine now. There was few updates and it ok.
Unfortunately, it doesn’t work now. I have three ihost in separate places, and when I connect ewelink devices toihost in one place, other ihosts lose connection to local ewelink deviced. I thought iHost work localy, and when i once connect ewelik devices to iHost it will work forever.
It’s really annoying limitation :confused:
