Login into Ewelink Account
Why is it not possible to login into Ewelink App and also into the ihost Homebridge plugin. The Problem ist every time the Homebridge is locked in
The App will be disconnected. When You sign into the Ewelink App again the Ihost Homebridge is disconeted.
Why is the Login not robust enough, to accept more than 1 login into the account.
I have a second shared account! but that does not fix the issue.
Configuration with the second shared account is blocked for changes on the original account.
This is something which for sure should be looked into and be implemented.
I have tried to use the share feature on my IO Phone ti avoid the disconnection on the ihost Hombridge Plugin. But by doing this you can not do any changes to You configuration on ewelink APP.
Suggest to have a look into this so that the Ihost Plugin which is logged into the ewelink Account and the Ewelink App and Web access could be logged into the Account.
try to create second ewelink account and share your home to new account then use it at homebridge
Well thank you but if You look into my previous Post,
I have a second account created and tested,
but using this account You can not change anything in Configuration etc.!
it is blocked to change Routines etc.
Also, the Smart ihost Hombridge Plugin does not allow the access with the second shared account. Will not work correct.
It needs access to the original first account to function correct!!!
so this second account is no option to fix the issue.
Hey,
You can use the eWeLink Smart Home Add-on to sync these devices to iHost and expose them to HomeBridge.
Hello, Thanks, this is done!
but you still need use the plugin in docker
to apply to Hombridge and you have to use the. Password and account to enable it in homebridge.
Sync only does nit fix the account probllem
