Trzvb scene manual mod with nspanel pro
Hello
Hello. Until yesterday I had a ZBridge Pro hub and TRZVB valves. The valves were set to manual, and I could open or close them using scenes. It worked fine.
Yesterday I received my nspanel pro. I unpaired the valves from my ZBridge Pro and added them to my nspanel pro. I deleted and recreated my scenes, but they no longer work. The scene runs successfully in eWeLink, and the temperature on the valve changes in the app, but the valve’s physical position doesn’t change. I’m using manual mode and setting it to 30 if I want it to open the valve or 15 if I want it to close. Why isn’t it working with the nspanel pro?
A ticket is opened at support
Same problem and I had already opened a post, but nothing
Yes it is very frustrating
