Timed boost for NS panel thermostat
I need a way of having the NS panel to have a boost setting for my heating,
For instance,
I’d like to set a 30 minute override for the NS panel thermostat to turn on my sonoff smart switch connected to my heating system
I used to do this via Alexa and ask her to turn on the upstairs radiators for 30 minutes and she would but since the new firmware and updates on the panels and the app, this functionality no longer works and the Ns panel instantly turns the heating back off because the temp for that schedule is already reached
Is there a work around or can this feature be implemented
For the time being, you may create a tap-to-run scene.
unfortunatly this does not work for the NS panel it wont switch between auto and manual mode
ive also tried creating a scene just for the smart wifi switch that controls the heating and that just clicks straight back off, the ns panel in auto mode is obviously taking priority, this seems like such a backwards step in the last update
"Strange, I tested it yesterday and the scene works correctly. Can you explain what is hidden under ‘Heating’ and ‘Hot Water Keep; Tower Rails’? Do you control the operating modes of the thermostats? And we are talking about Sonoff TRVZB, right?
