NSPanel PRO Thermostat suggestion
I have an NSPanel Pro and try to set up its thermostat function.
It would be great to be possible to add more actuator for one thermometer. In my case there is a heat source(water pump) and a fancoil, which need to start or stop at tha same time.
I can make it happen with smartscenes, but it needs internet connection.
It would be graet, if NSPanel pro could cope with a few simple smartscenes in case of the internet is down.
Also in auto mode of the thermostat I can add only 6 schedules for a week. It is very few. Most thermostat can handle 6 schedules for a day!
I also would like to be able to set the hysterises to 0,3 Celsius. I have a buffer tank and the thermostat switch on-off only a waterpump(and fancoil), so there would be no strain on the boiler for the more frequvent on-off cycle, but the room temperature would be more even.
Thanks.
Thank you very much for using NSPanel Pro. We are sincerely appreciate your valuable feedback.
We were busy rolling out V4.x App for NSPanel Pro. This version has been completely rewritten in Kotlin and it should provide much better performance and stability.
We will work on your suggestion ASAP.
@LMX is our new product manager in charge of NSPanel Pro. He and I will keep you posted on this feature.
