SWV valve is really great to have a distant command to a “tap”
But (excepting if i didn’t understood how it works) … It is nearly impossible to have a smart automation
if i manually put it on (button in ewe link), it is impossible to automatically limit the time of using it .. The “automatic / manual” button always come back to manual (why ???)
i want to automatically water the garden on sunrise but only if it is not already raining … Wouldn’t it be possible to have the weather information as a trigger ?
I will be posting interesting projects that I have created on this forum. I will go to the first project, the customer wanted to create an automatic watering system for the garden.
I have already pointed out several times that they have an “intelligent” valve, but with the options available to me (which are none), they made it a stupid valve.
It is possible to automate it but in the style of open at , close after a certain time if it rains do not water. If you want to repeat watering every day, you need to make multiple scenes because it cannot be set within one scene. Here I described it:
I looked at control units like Hunter. Expensive devices but without any intelligent functions.
I bought valves, fittings, 5x sonoff swv-bsp, 2x snzb-05p. I have a customer iHost control unit.
For the sake of interest, the connection at the very top is used to connect the compressor. So that it is possible to comfortably blow water out of the pipe. So that the pipe does not burst in the winter.
One SNZB-05P sensor is placed next to the pipes and the cable is wrapped around it so that it detects any leaks in the pipes.
The last SNZB-05P sensor is placed under the roof and the cable is brought out of the roof and wrapped around a plastic holder. The purpose of this construction is to determine if it is raining.
Every other day, it turns on the irrigation shortly after sunrise. Each valve is in automatic mode, where it is set to 25 liter. When it starts to rain, Tal turns off the irrigation for half a day.
You must be careful to have the optimal number of valves turned on at once, otherwise there is a risk that the water pressure will not be strong enough.
Home assistant and eWelink are different control systems. Therefore, they do not see scenes between them. You need to decide whether the valve will be controlled by eWelink or Home asisstent.
I have written several times that SWV cannot be fully utilized. Each time I have been completely ignored. Can you show me how you have it done? So I can advise.
