How is it that in the scene you can’t set anything except on/off/reverse and how long to water or how many liters. Does Sonoff punish iHost users and is it even possible to execute the above options?
Hello, thank you for your feature suggestion. To help us better understand your needs and design truly practical features, we would like to ask you the following:
What user purpose or automation scenario do you expect to achieve by adding these parameters? For example, “Do you want it to automatically cycle through watering according to a set irrigation pattern and interval?”
Do you want these parameters to be trigger conditions for a scenario or actions executed within it? Providing a specific scenario example would be very helpful so our technical team can more clearly assess the requirements.
We look forward to your reply and thank you for your support!
Hi, it would be good if it was possible to set how many times a day it should start watering and for how long. And within that watering, set whether it should water within a certain time limit or a certain volume of water in each cycle.
Hello, thank you for your detailed feature suggestion. We have fully recorded your request and submitted it to the technical team for evaluation. We will keep you updated on any specific version plans or progress in the future. Thank you again for your feedback!
