Sonoff garden
Can someone explain to me what they added these options for?
When in reality I couldn’t configure the above-mentioned options in the scene, and even when I did set them up, it still doesn’t remember the settings.
Is there anyone from Sonoff here who’s open to discussing how these functions could be improved?
My idea is that your valves should be truly smart, especially the ones designed for irrigation. Right now, they can only be turned on/off either manually, by a scheduler, after a certain amount of time, or after a specific water volume has been exceeded.
My idea is that it should be possible to configure all of these functions through scenes, plus set how many times per day the irrigation should run and how long each watering cycle should last.
There should also be an option to connect an external sensor that detects rain and completely disables the valve when it’s raining (this does not work well through scenes).
